Engine cranks but will not start
244,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
JAXON516
Fuel level indicator goes below empty when I turn the car on. Gas tank is full. Fuel reset button has been reset.
May 29, 2021 at 3:11 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Your fuel pump might not be working. It sounds like you might have a weak or failing fuel pump not providing adequate fuel pressure. I would suggest performing a fuel pressure test. Here is a tutorial showing what is involved:
After performing this test get back to us with the results and we'll go from there. I've attached a picture below showing the proper fuel pressure for your truck. Hope this helps and thanks for using 2CarPros.
May 29, 2021 at 12:46 PM
