Engine cranks but will not start
160,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
RYAN MCFARLAND
Engine cranks but will not start. I have checked fuel pressure 37 psi at fuel rail and the fuel pump relay energizes in ignition mode. I have also checked the inertia switch which has not been tripped what else should i go through?
Feb 21, 2017 at 3:15 AM
JDL
  • 16,098 POSTS
You should have initial prime when you first turn on the key, no crank. At the moment, I do not know if the fuel pump has voltage with engine cranking. On your vehicle, you should not need rpm signal for initial prime, but with engine cranking, you need rpm signal. Do you have TFI module attached to distributor? Ford has had problems with those modules. I cannot be certain that is your problem? I know some people that carry a spare module in their glove box, because of problems.
Engine cranking, do you have spark at the plugs? Any applicable trouble codes?
At the top of page is a link for repair guides, a lot of good information.
Feb 21, 2017 at 4:52 AM
RYAN MCFARLAND
I got it thanks no spark to ignition coil either was module i jumped distributer straight from battery then tried ignition and bam there she is
Feb 26, 2017 at 10:02 PM
  • 55,808 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Best, Ken
Feb 28, 2017 at 3:32 AM
