Engine cranks but will not start
240,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JAMES WRITER
I have power to everything in the truck . Turn the key to on position and my warning lights in my instrument panel don't come on when cranking the engine over my tachometer and speedometer start jumping which never has done that before the oil pressure gauge comes on temperature gauge comes on volt gauge comes on. just the brake warning light and check engine warning light don't come on.
Jan 3, 2020 at 3:24 PM
JIS001
  • 3,412 POSTS
First thing you should check is for fuel pressure and spark. Here is a link on how to do the test. Once you have done the checks let us know if there was spark and what fuel pressure reading you are getting.
Jan 4, 2020 at 5:18 PM
JIS001
  • 3,412 POSTS
I apologize, I did not attach the link.
The link to the repair guide will help you do some basic tests. Please let us know if there is spark or fuel pressure.
Jan 5, 2020 at 10:07 AM
