Engine cranks but will not start
220,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
IGNACIOCORIA
So i'm not sure if my problem is electrical or if it's something to do with my fuel system. when i insert the key and turn it to the on position some times i can hear the fuel pump turn on but only on the first time. if i try to open the switch again I can no longer hear the fuel pump. i checked all of my fuses, fuel pressure and everything seems to be fine, but when i try to crank the engine i have no spark in my coils. spark plugs, wires, the throttle position sensor, those are all new. i also bought a new battery. my truck was working just fine but just pulled up to a gas station to fuel up and from there it just didn't want to start no matter what i tried. so please if you can help me out and have an idea of what it could be let me know. i need to get it running again. It is my work truck and i haven't been able to work because of it. thank you
Sep 18, 2021 at 11:32 AM
So if you turn the key and the engine only cranks but does not start then we need to start with fuel and spark.
Here is a video that will help with this issue and get us started:
https://youtu.be/dCjmRL3p4Cs
However, if you checked the fuel pressure, what was the PSI when the engine was not starting?
Also, how did you check for spark to see that you were not getting spark? Did you pull a plug or wire and hold it against the block and crank the engine?
If you don't hear the fuel pump and you don't have spark then we could have an issue with the crank sensor.
I am attaching the info below from the manual on how this works but if you are not getting fuel or spark then the crank sensor would be the first place I would look.
Let me know about this info and we can go from there. Thanks
Sep 22, 2021 at 8:19 AM
AMPEER
I've changed everything. The code P0315
Nov 9, 2026 at 9:53 AM
  • 55,808 POSTS
You need to do a crank shaft relearn or the engine will not start up
P0315 — Crankshaft Position System Variation Not Learned
You will need a scanner for this. I know this happens sometimes when changing the crankshaft sensor.
Nov 13, 2026 at 9:13 AM
AMPEER
If it won't stay started how can I do a mechanic relearn?
Nov 13, 2026 at 1:20 PM
  • 55,808 POSTS
Here is a video to help you
https://youtu.be/-Ib3Lkde3Wo?si=nY4vrTwGeW6oFicg&t=417
Nov 15, 2026 at 7:17 AM
