Engine cranks but will not start
238,172 MILES • 6.8L • V10 • 4WD • AUTOMATIC
JJGILLIAM 0626
Fuel doesn't seem to be getting from the tank to the engine. I have replaced the fuel filter, fuel pump, ignition coils, spark plugs, and fuel pump inertia switch. Also all fuses and relays seem to be okay. Could it be that I need to replace the fuel injectors?
Apr 24, 2019 at 8:57 AM
BMDOUBLE
  • 1,139 POSTS
Can you hear the pump running when the key is turned to the run position? If you can hear it turn on then inspect the lines for rust or kinks. If you can’t hear it turn on, be sure that you are getting power at the pump. You can also blow through the fuel lines from the filter to the fuel rail, with the fuel lines at the rail unhooked it should blow through freely.
Apr 24, 2019 at 10:31 AM
