Hi there. My car does not start anymore. It cranks over but no start, not even a hint of trying to start. I have replaced the fuel pressure sensor and tested the coils for spark, bought new spark plugs, tested the TPS, checked and cleaned the MAF sensor, checked fuel pump and fuel pressure (my fuel pressure gauge tester is graded in a 1 - 10 scale and I get a 6 for pressure, not sure if that means 60 psi?), tested and cleaned the fuel injectors, tested the compression (125+ psi) in each cylinder, fully charged battery, got no codes from PCM with OBD scanner and no CEL. I don't know what else to look for, I got good spark, fuel pressure and air but it won't fire. If I crank it for too long or to many times the number 2 and 3 cylinders will hydro-lock with fuel.
Any ideas would be appreciated. Thanks.
Jan 13, 2020 at 10:06 AM
