Automatic six cylinder. California Jeep.
Engine runs great. After the vehicle is started I can drive all day s*** engine off start right back up perfect.
Next day engine cranks cranks cranks refuses to start. Takes 15 minutes turning over until finally coaxed to start then no problem starting shutting off etc. Almost like it’s initially starved for fuel.
New carburetor.
New distributor cap.
New points.
New plugs .
New plug wires.
New solenoid .
New starter .
New started relay.
Third mechanic found vacuum leak in four connector vapor canister. He sealed the vacuum hose. Runs like a champ.
Haven’t replaced the coil yet.
I’m suspecting a fuel issue.
Timing was adjusted properly.
Any help please?
New carburetor.
New points.
New plugs .
New plug wires.
New solenoid .
New starter .
New started relay.
Any help please?
May 14, 2019 at 10:35 AM
