Engine cranks but does not always start on first attempt?
95,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • MANUAL
DCROUCH92
  • 7 POSTS
I have a 2007 R56 N14 mini copper, for a long time now the car has struggled to start on the first attempt once it has been sat for a long period of time. I have replaced the low-pressure fuel pump, HPFP, fuel filter, spark plugs, camshaft position sensor and changed the battery but none of these seem to have solved the issue. The car appears to run fine and starts on the second attempt but struggles on the first one. I have had the fuel pressure measured at 5 BAR but am now running out of ideas for what could be causing this issue. Any help you could give would be greatly appreciated. thank you
Feb 7, 2025 at 7:11 AM
  • 55,694 POSTS
I have seen the engine coolant sensor get weak and give false readings to the PCM which will cause this issue. We can tell for sure if we scan the computer to see what the readings are, this guide can help:
I have also seen a dirty throttle body cause this issue as well. Here are two more guides to help us see what's going on:
and
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Here is the coolant sensor location in case the readings are off. Check out the images (below). Please let us know what happens.
Feb 8, 2025 at 2:47 AM
DCROUCH92
  • 7 POSTS
Hi Ken thanks for your reply, I took the throttle body out and gave this a clean as it was dirty however I don’t think this has resolved the issue. The thermostat has recently been replaced so I don’t believe the issue lies with that as it was like it before and after the replacement. I have brought some injector cleaner which I will put into the fuel from tomorrow to see if that helps anything. Otherwise, do you have any more ideas of what could be causing the issue?
Also, I forgot to mention before I have also replaced the Vanos solenoid.
Feb 11, 2025 at 2:04 AM
  • 55,694 POSTS
Did you run the codes? Like I say, I have seen the engine coolant sensor cause a hard starting issue.
Feb 11, 2025 at 2:16 AM
DCROUCH92
  • 7 POSTS
The car isn’t currently showing any codes.
Feb 11, 2025 at 2:42 AM
  • 55,694 POSTS
I would use a scanner to see the engine temperature and then if it is off change the sensor out.
Feb 12, 2025 at 1:02 AM
DCROUCH92
  • 7 POSTS
I checked the coolant temperature after I drove home today, and it was at 105 C this was after a 30 minute journey.
Feb 13, 2025 at 5:09 AM
  • 55,694 POSTS
That's seems a little high to me, was it a hot day?
Normal operating range: 85°C to 97°C
You might to try swapping the sensor out to see if the reading changes.
Feb 14, 2025 at 2:15 AM
DCROUCH92
  • 7 POSTS
Hi Ken, I fitted the new temperature sensor. I haven’t checked the reading yet, but it hasn’t changed the starting issue.
Feb 18, 2025 at 5:28 PM
  • 55,694 POSTS
Okay, let's do a compression test to see if it is low which will cause hard starting.
Please go over this guide:
Feb 19, 2025 at 2:18 AM
DCROUCH92
  • 7 POSTS
I completed the compression test and the readings were a lot lower than the guide said. The first cylinder I tested was at about 103/104 PSI and the other 3 were exactly the same at 95 PSI.
Feb 23, 2025 at 7:57 PM
  • 55,694 POSTS
Yep that is low. The engine can be worn out, the timing chain has jumped one tooth or the camshaft Vanos are not working/worn out, I would do a leak down test on the engine to see if the valves/rings are leaking or if it is a timing issue.
Feb 24, 2025 at 3:38 AM
DCROUCH92
  • 7 POSTS
I did have the timing chain replaced and have replaced a Vanos solenoid. How would I go about a leak test or is this something a garage would need to do?
Feb 24, 2025 at 4:03 AM
  • 55,694 POSTS
Here is a video to show you how but it sounds like the engine is worn out. Let me know how is goes.
https://www.youtube.com/watch?v=h993q16Oul4&pp=ygUJbGVhayB0ZXN0
Please go over this guide and get back to us.
Feb 25, 2025 at 1:28 AM
