Engine cooling fan not functioning?
2012 FORD F-150
235,345 MILES • V6 • TURBO • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
Hello, the vehicle had a blown head gasket, it had been replaced but it was observed that the engine cooling fan is not functioning, even when the A/C is put on, none of the fan is rotating. All fuse has been checked, and they are in good condition.
What could have been the cause?
Could I have the wire diagram for the system?
Nov 30, 2024 at 11:55 PM
  • 55,222 POSTS
It can be the cooling fan motor itself; does it seem to spin freely? There is only one fan that will run, the PCM turns on the other fan if the engine is super-heated. There are fuses that need to be checked which are in the wiring diagram for the fuses.
This guide can help:
Dec 1, 2024 at 4:47 AM
BLESSING EWOBOR
  • 753 POSTS
Thank you very much.
The cooling fan is rotating properly when connected directly to the battery.
Dec 2, 2024 at 1:07 PM
  • 55,222 POSTS
Okay, good, did you check the fuses in the wiring daigrams above?
Dec 3, 2024 at 1:55 AM
BLESSING EWOBOR
  • 753 POSTS
Yes, I did, I checked the fuses, and they are in good condition.
Dec 11, 2024 at 8:51 AM
  • 55,222 POSTS
Okay, I would use a scanner to see how hot the PCM thinks the engine is. You may have a cylinder head temperature sensor that is not good. Here is the location and a guide to help us see what's going on.
Dec 12, 2024 at 4:37 AM
BLESSING EWOBOR
  • 753 POSTS
Hello, at what temperature is expected for the fan to comes on?
Dec 14, 2024 at 9:44 AM
  • 55,222 POSTS
They should come on at 210 - 212 degrees, what does the scanner say the engine temp is?
Dec 15, 2024 at 2:38 AM
BLESSING EWOBOR
  • 753 POSTS
Do you mean 210 - 212 degree Celsius or Fahrenheit?
Dec 15, 2024 at 1:07 PM
  • 55,222 POSTS
Fahrenheit, or about 99 degrees Celsius.
Dec 17, 2024 at 1:59 AM
BLESSING EWOBOR
  • 753 POSTS
Dec 17, 2024 at 10:13 AM
