After overheating and replacing the radiator van will not start
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
FRANCHESKA26
It was overheating and then started smoking out of the hood. So I pulled over and opened the hood and there was coolant sprayed everywhere under the hood. I replaced the radiator , but now the van won't start. (It wouldn't start after overheating ) but even after replacing the radiator it still won't start. What could be the issue now ?
Sep 11, 2019 at 10:37 PM
SCGRANTURISMO
  • 4,897 POSTS
This could a problem with your engines cylinder head that has warped, causing the head gasket to fail. What happens when your vehicle overheats is that the aluminum cylinder head can not handle the same amount of heat the your cast iron engine block can and slightly deforms, or warps. This allows the cylinder head to pull away from the engine block, which, in turn, causes head gasket failure. he engine's compression is lost through the compromise in the blown head gasket causing your vehicle not to start. Here is a link below for you to go to so you can check your vehicle's engines compression:
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Sep 12, 2019 at 6:11 AM
