Engine cooling
206,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
LAUREN MARIE GILLIE
The water in radiator jug boils after I drive a few miles, but carburetor gauge wasn't up past normal. When I stop oil light blinks.
Jul 12, 2019 at 9:58 PM
SCGRANTURISMO
  • 4,897 POSTS
Okay, these might be two separate issue. First I would check to see if your thermostat is opening. Here is a couple of links for you to go to:
https://www.2carpros.com/articles/how-an-engine-thermostat-works
I wouldn't drive until I got these problems diagnosed and fixed. In the diagrams down below I have a factory troubleshooting guide for your vehicle's Oil Pressure Warning Indicator Lamp. Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 12, 2019 at 11:22 PM
