Losing coolant
2000 DODGE DAKOTA
160,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
JAMES DOSSETT
Foam in radiator, loses water, no water in oil.
Oct 19, 2019 at 2:33 AM
SCGRANTURISMO
  • 4,897 POSTS
This is probably going to be a blown head gasket. The foam is probably going to be from combustion gases mixing with the coolant and pressurizing the cooling system. Here are a couple of tests to see if your vehicle's head gasket[s] are blown below:
Please go through these guides and get back to us with what you are able to find out,
Thanks,
Alex
2CarPros
Oct 19, 2019 at 9:57 AM
