Where is the Engine Coolant Temperature Sensors located?
99,489 MILES • 3.6L • V6 • AUTOMATIC
VICTORIA STRAIGHT
I have the car listed above 300S AWD 8-speed automatic transmission. How do I locate the two Engine Coolant Temperature Sensors?
Jan 21, 2023 at 5:54 AM
  • 55,612 POSTS
It looks like there is only one engine coolant sensor which is on the left side of the engine toward the rear of the cylinder head. here are the instructions and the location of the sensor in the images below. Please let us know if you need anything else to get the problem fixed.
Jan 22, 2023 at 4:34 AM
VICTORIA STRAIGHT
I will change this out tomorrow. Thank you so much.
Jan 23, 2023 at 12:33 PM
  • 55,612 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Jan 24, 2023 at 4:20 AM
