engine coolant temperature sensor location
130,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
RYAN MARTIN2
So I have been having an issue with my car overheating. And I have found out there could be three reasons as to why it is. I have replaced two of the three parts it could have been but they did not fix the issue. The last part I need to replace is the engine coolant temperature sensor, however I do not know where it is located and cannot seem to find it. The other two parts I have replaced are the thermostat and the radiator fan. Which the fuse in my fan had gone out, so it was a good thing I got that done. If I could get some help that would be greatly appreciated. ^-^
Apr 16, 2018 at 4:01 PM
MIKE H R
  • 3,094 POSTS
location coolant temperature sensor. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Apr 17, 2018 at 4:06 AM
I am attaching a lot of information on this sensor and how to replace it.
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Below you will find the location attached to this post so that you are able to find it. It is on the back side of the engine but should be accessible.
Let us know if you have other questions. Thanks
Dec 13, 2020 at 6:14 AM
