Where is the engine coolant temperature sensor located?
110,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
YASUYOSHI CHICA CHIKAZAWA
overheat problem.
i needs know location of engine coolant temperature sensor.
Aug 13, 2021 at 12:37 PM
  • 110,246 POSTS
This vehicle has a cylinder head temperature sensor (CHT). The sensor is located on the rear of the right cylinder head.
If you look at the attachments below, they provide the directions for removal and replacement.
I hope this helps. Let me know if you have other questions.
Aug 13, 2021 at 3:22 PM
