Engine coolant temperature sensor
2010 MERCEDES BENZ ML350
108,000 MILES • 6 CYL • AWD • AUTOMATIC
JOHN J66
Hello, I was trying to find the location of the sensor due to the fact i had the engine light come on. It is a p0128 code, which Autozone said is either thermostat or sensor so i figured i would change both. Thanks.
May 22, 2016 at 12:37 PM
SATURNTECH9
  • 30,869 POSTS
Do you have a 3.0 or 3.5L engine? More then likely it is a bad thermostat all the code P0128 I have seen on all different make cars has been a bad thermostat.
May 22, 2016 at 3:41 PM
JOHN J66
Thanks, I will check the engine , not sure what, but i figured the sensor was not expensive so i would just change it when i change thermostat. I still need to find out where the sensor is located. Appreciate the response.
May 22, 2016 at 9:21 PM
SATURNTECH9
  • 30,869 POSTS
On the emissions label under the hood it should tell you what size the engine is.
May 23, 2016 at 3:18 AM
JOHN J66
Thanks , I will check under the hood.
May 23, 2016 at 4:27 AM
SATURNTECH9
  • 30,869 POSTS
You are welcome.
May 23, 2016 at 5:17 AM
