Engine coolant temperature 199-203 but high engine oil temperature of 243
2009 FORD F-350
230,000 MILES • 6.4L • V8 • TURBO • 4WD
JIMMYHARTLEY
I have a 2009 6.4 power stroke, with engine oil temp issues . Had a leaking oil cooler that went into coolant system . Flushed system good. Changed oil cooler , flushed again with Prestones flush/degreaser and temperature slowly climbs up to 243 but coolant stays at 199-203. I’ve re-flushed it four times. Both temperatures are right together at startup until coolant reaches its 199 mark, but oil keeps slowly climbing. Any ideas?
Dec 19, 2018 at 7:00 AM
Good afternoon,
Are you using the correct weight oil? That is critical.
I would also use full synthetic oil as well.
Fluid Types
Engine Oil .................... Preferred Motorcraft Motor Oil 15W-40 Super Duty
Ford P/N .................... XO-15W40-QSD
Engine Oil .................... Motorcraft Motor Oil 10W-30 Super Duty
Ford P/N .................... XO10W30-QSD
Ford Specification .................... WSS-M2C171-E
Capacities
Engine Oil .................... 15.0 quarts (14.2 Liters)
NOTE: Includes 1 quart (1.0L) in oil filter.
Dec 20, 2018 at 1:46 AM
JIMMYHARTLEY
Not sure . I would assume. The shop changed it. That would make a big difference to bring the temperature down?
Dec 20, 2018 at 1:48 AM
yes, the type and viscosity are critical to oil temperatures. a lot of shops do not know or care about it. they just put in any oil they have to maximize their profits.
Dec 20, 2018 at 2:05 AM
JIMMYHARTLEY
But wouldn’t my coolant temperature be up as well? It’s reading 199 and engine oil temperature is 243.
Dec 20, 2018 at 3:16 AM
no, the coolant is controlled by the thermostat and the radiator.
Dec 20, 2018 at 4:24 AM
JIMMYHARTLEY
Thanks Roy.
Dec 20, 2018 at 7:05 AM
You are welcome.
Always glad to help.
Dec 20, 2018 at 1:46 PM
