Engine coolant sensor vs sender
130,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TBOAT13
  • 16 POSTS
I had problem with cooling fans not coming on, even after engine reached overheat Temps. I replaced coolant temperature sensor and fans were now coming on. When I returned to my project, the fans weren't shutting off unless ignition was off. Also, temperature gauge was not registering temperature even after disabling fans. I may have gotten a bad sensor, or I am missing something. Can you please advise me on next steps?
Nov 25, 2025 at 2:01 AM
CARADIODOC
  • 34,414 POSTS
The first step is to read and record any diagnostic fault codes. Chrysler made doing that yourself much easier than any other manufacturer. Cycle the ignition switch from "off" to "run" three times within five seconds without cranking the engine. Leave it in "run", then watch the code numbers appear in the odometer display. You can go here:
https://www.2carpros.com/trouble_codes/obd2/p0300
to see the definitions, or I can interpret them for you. My guess is you're going to get a code related to the coolant temperature sensor. That code will give us the starting point. It should turn on the Check Engine light too.
To double-check you're on the right sensor, check that the two wires in the connector are tan / black and black / light blue. First, check the terminals for corrosion and being stretched out, then let me know what you find.
Nov 25, 2025 at 3:28 AM
TBOAT13
  • 16 POSTS
Tried to get codes, but process you described didn't work.
Nov 25, 2025 at 6:47 AM
TBOAT13
  • 16 POSTS
Obtained a code reader and got code of 0118- ECT circuit high input.
Nov 25, 2025 at 9:37 PM
CARADIODOC
  • 34,414 POSTS
Dandy. The Engine Computer feeds that sensor with 5.0 volts, then the circuit draws that down to less. The acceptable range is 0.5 volts to 4.5 volts. When there's a break in the circuit, that 5.0 volts doesn't get pulled down. It stays at 5.0 volts, and since that is not within the acceptable range, it sets the code for voltage too high. (That 5.0 volts is "seen" inside the computer where that circuit originates).
By far the most common cause of this is a stretched or corroded terminal in the sensor's connector. Next would be a break in the 5.0 volt feed wire or a break in the ground wire. Both of those have a very small area in the circuit to develop this problem. Most of those two wires also go to other sensors. If there was a break in a section they all have in common, there would be more codes set for other sensors. The sensor is the least likely suspect for this code because it has just one rather reliable part inside.
This is the same condition that occurs when the sensor is unplugged while the ignition switch is on. The Engine Computer doesn't know true coolant temperature, so it defaults to turn the radiator fan on in case the engine is running too hot. It's also a quick test we use to check fan operation. Once the plug is reconnected, we have to erase that fault code so it doesn't confuse someone with a new problem in the future. If we don't erase that code, the Check Engine light will go off when the plug is reconnected, or at the next ignition switch cycle. If no break occurs again, the fault code will self-erase after fifty engine starts.
There's two ways to approach this. The easiest is if you're using a scanner, or if your code reader can display live data, find the screen that shows coolant temperature sensor voltage and watch that while you wiggle the sensor connector. If you see the voltage change erratically, those terminals must be repaired.
The second way is with voltage readings from a digital voltmeter, but there's one important point. The readings are only valid when taken with everything connected and plugged in. You must back-probe the terminals through the rubber weather seals alongside each wire. Start with the tan / black wire. That one must have 0.5 to 4.5 volts. If you find 0.0 volts, that wire has a break in it between that terminal and the splice where it goes to other sensors. That should mean roughly a foot or two of wire.
If you do find between 0.5 and 4.5 volts, the circuit is working at this time. Erase the fault code, then it shouldn't come back right away. If it comes back later, there's an intermittent problem we have to find. For that, any testing will have to wait until the problem is occurring.
If you find 5.0 volts, that wire is okay. The break is after that point. Measure the voltage on the black / blue wire. Normally that one will have 0.2 volts. If you find 5.0 volts on this one, the break is in that wire, again, between the connector and the splice that goes to other sensors. If you find 0.2 volts, (0.0 volts for all practical purposes), along with 5.0 volts on the first wire, one of those connector terminals is spread, or, less likely, the sensor is open. We can verify a bad sensor with a resistance test if that becomes necessary.
For the ignition switch test, the most common causes for it to not work is you went too far and the starter engaged, or "off" and "run" weren't reached three times within five seconds. I've also run into trouble when I didn't start from "off". I started with the switch already on. Turning it all the way to "crank", even for just an instant, is the signal for the Engine Computer to exit that test mode. On most models, if you think you didn't catch all the numbers, the sequence will read out again from the beginning if you turn the ignition switch back to "off", then back to "run", just one time. If the odometer display goes blank, it's preparing to display the code numbers, but you may have to wait a few seconds for it to start.
Let me know what you find for voltage readings.
Nov 26, 2025 at 4:54 AM
TBOAT13
  • 16 POSTS
I found that moving/pushing/pulling on those wires activated non running fan and would deactivate fan if running. I went ahead and replaced the pigtail and everything seems to be working fine now. I haven't tried to use key on/off to get codes yet, but will try that when I get a chance. Thanks.
Dec 11, 2025 at 10:44 PM
CARADIODOC
  • 34,414 POSTS
Dandy news. I'm happy to see you solved it.
After rereading my last wondrous reply, it hit me that I made a major mistake that must be corrected. Every part of my sad story stays the same related to the sensor's ground wire that is spliced in with those from some of the other sensors. The glaring mistake is the 5.0-volt supply wire is not tied in with any other sensors. To do so, as they do with throttle position sensors and MAP sensors, would make them inoperative. In fact, that feed circuit is also the dedicated sensing circuit for coolant temperature.
To say that a different way, we can see and measure the 5.0-volt feed and the signal wire voltages at the throttle position sensor. We can only see the signal voltage at the coolant temperature sensor. The 5.0-volt feed is inside the Engine Computer.
Hope my friends don't see my mistake. Please come back to see us with your next problem.
Dec 12, 2025 at 4:16 AM
