Where is the Engine Coolant Sensor located?
62,000 MILES • 2.7L • V6 • AUTOMATIC
GEMMINYE
Where is the engine coolant sensor location for a 2020 Lincoln Nautilus reserve?
The engine coolant over temperature light is coming on but the car was not on prior for it to be overheating.
Jan 11, 2025 at 8:21 AM
CARADIODOC
  • 34,413 POSTS
Ford no longer uses a coolant temperature sensor. Here's the procedure for the cylinder head temperature sensor for a 3.5L engine.
Jan 12, 2025 at 2:03 PM
