Where is the Engine Coolant Sensor located?
320,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
LAUREN4768
Location needed.
Apr 27, 2025 at 2:49 AM
MECHTRIX
  • 539 POSTS
Follow the hose from the radiator. it should be right near where the hose connects to the engine hope this helps good luck.
Apr 27, 2025 at 7:31 AM
  • 55,511 POSTS
The coolant sensor of the temperature is on the left side on the engine, check out the images (below). Let us know if you need anything else.
Sep 5, 2025 at 8:09 AM
