Where is the engine coolant sensor located on a 1995 Buick lesabre
Jan 1, 2016 at 10:21 PM
HMAC300
✓Experienced Mechanic
Here is the location of the engine temperature coolant sensor. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to enlarge)
Jan 2, 2016 at 1:46 AM
MCCORDMICHAEL
MEMBER
Thanks, do I need to remove the throttle body to replace?
