Engine coolant over temperature
9,000 MILES • 1.6L • 6 CYL • 4WD • AUTOMATIC
MEAELLEN
When it’s really hot outside the thermometer will go up with the air on. when it starts to rise I turn the air off and it goes back down. When the car is off and I start it the engine coolant over temperature light goes on and then goes off.
Jul 4, 2019 at 9:38 PM
SCGRANTURISMO
  • 4,897 POSTS
This is normal. When you first start your vehicle the over temperature bulb should illuminate and the turn off. This is what is known as a bulb check and is completely normal. Also when your A/C turns on the A/C compressor clutch kicks in and the engine has to turn the A/C compressor which makes it work harder. As a result the temperature should rise a little, but your vehicle's engine cooling should kick on to compensate when the temperature reaches a certain point.
Thanks,
Alex
2CarPros
Jul 5, 2019 at 11:36 AM
