Engine coolant over temperature light will not go off
74,800 MILES • 1.5L • 4 CYL • AUTOMATIC
SKIZZEE30
It comes on in the "on" position. My car never overheated and still does not. I have had the thermostat housing and sensor changed and it does the same thing. Because of the light it has disabled my speed and air. The car runs idle but that’s it. I have tried several methods to reset the computer. Any help will do.
Aug 24, 2019 at 4:40 AM
  • 55,732 POSTS
This is common when the A/C system is slightly overcharged the computer is alerted via the high pressure sensor and the warning given. can you try to drive it with the A/C off to see if it does the same thing? Here is a guide that shows the pressures and how to test them:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Aug 26, 2019 at 7:47 AM
AARON118
Where did you find the thermostat at?
Dec 6, 2021 at 8:54 AM
  • 110,248 POSTS
Hi Aaron,
AS far as the thermostat, is it for the same year, make, and model listed above?
Let me know. Also, confirm the engine size.
Dec 8, 2021 at 11:47 AM
