Engine will not crank and coolant temperature light on
2013 FORD FUSION
135,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
ALICIA HUNT
MEMBER
1 POST
The engine coolant over temperature light is on and car will not crank
Aug 5, 2018 at 2:44 AM
✓Experienced Mechanic
Yes, this is a safety device to help you from damaging the engine. If the engine has cooled down can you check the coolant level. Here is a video to help you:
