Engine coolant over temperature
116,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
ASHLEY HORTON
I recently replaced my alternator and when I start the car it runs fine for the first two or three minutes. Then I receive an error that my coolant temperature is too high and the car shuts off. It starts right back up and runs or a minute or two again then shuts off. I checked the belt, its ran properly, all the pulleys are moving properly. Could it be the coolant temperature sensor? I just ordered and OBDII scan tool should be here Friday so I don't have any codes yet.
Mar 6, 2019 at 12:26 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just a quick question first. When this happens does the check engine light come on or flash? Most local auto parts stores like AutoZone will check codes for free as opposed to you buying a code reader.Here is a tutorial showing what is involved in checking codes.
Hope this helps and thanks for using 2CarPros. Feel free to ask any further questions.
Danny-
Mar 6, 2019 at 1:56 PM
ASHLEY HORTON
The check engine light is on steady no flashing.
Mar 7, 2019 at 4:23 AM
  • 55,709 POSTS
It sounds like the temperature sensor has gone bad. Here is guide to walk you through the steps of changing it and the sensor location for your car and instructions below:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Mar 11, 2019 at 3:21 AM
