Engine coolant over temperature - Engine overheating
44,000 MILES • 1.5L • 4 CYL • AUTOMATIC
CHUCK.RICH
I am having a problem with my car. One time it overheated on me, I was able to get it home. The next day I get into my car did not even fully turn it on and it is saying "engine coolant over temp"? So I dd not think too much of it I just let it sit for a week or two and i am still getting the same message. Any suggestions? Taking it to the dealerships out of the picture.
Jun 12, 2016 at 11:55 AM
  • 31,937 POSTS
It sounds like you have a coolant leak which will cause both issues here is a guide to help you see how to find the leak.
https://www.2carpros.com/articles/car-is-leaking-coolant
If everything looks okay I would try replacing the engine coolant sensor here is a guide to help you see what you are inf or when doing the job.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Here is the location for your car. Check out the diagrams (Below). Please let us know what happens.
Cheers
Jun 12, 2016 at 1:01 PM
RENEE L
  • 1,260 POSTS
Hi Chuck,
Here is a link to article from this site regarding over heating issues. This is a step by step guide on how to troubleshoot and repair an automotive engine overheating or running hot problems. Though appearance may vary the process is similar for most vehicles.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
I you need any further advise please come back to 2CarPros as we are always happy to help and thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Jun 13, 2016 at 9:13 AM
MASHTALOV1
My Fusion was doing the same temp Gage was fine and a second later went into overheat, Mine did this 4 times in 3 days. It's at the dealership now to be repaired. They said there was a recall on the engine cooling fans and fuses. My fusion only had 12,322 miles on it.
Apr 5, 2017 at 5:51 AM
  • 55,694 POSTS
Hey,
Great addition to this thread! Please feel free to help out on the site whenever it can add information that will help.
Best, Ken
Apr 8, 2017 at 4:36 AM
MGARCIA07
My fusion first overheated from low amounts of coolant after it was drained from the radiator so I had added more coolant and bleed the system still overheated after that and got a P1285 code for cylinder head over temperature sensed and so the thermostat, radiator, water pump, and coolant temperature sensor have been replaced... Car does not overheat when idling only when driven and when driven it moves from normal temperature and takes a straight shot to H.. The gauge does the start to overheat slowly it is a straight shot to H
Apr 8, 2017 at 4:37 AM (Merged)
HMAC300
  • 48,601 POSTS
have the coolant system pressure checked for an internal leak like ahead or intake gasket.
MGARCIA07
Hey Hmac300,
The system has been pressure check for leaks and nothing
HMAC300
  • 48,601 POSTS
then have it checked to see that it is actually overheating by putting a temp guage on the return hose as it may be an electrical problem with a sender or gauge. it may not be doing what iti says.
JDEMER21
Ford fusion sel v6 started making a rattling noise while accelerating so pulled over and shut off the car then restarted and noticed the temp gauge went all the way up when it wasn't before I'm thinking water pump but not sure.
SEANGRANT00
  • EXPERT
  • 334 POSTS
If the car was overheating, could be low on oil or coolant. If it was the water pump, typically you will be able to see a constant drip or stream of water coming from the front of the engine. You will need to check the coolant level after it is cooled off to make sure it is full. Also check your oil level. I would not try to drive the car until you at least do these two things or you could risk ruining your engine and have to replace it. When the car is overheating do not drive it! Let me know what you find out.
JDEMER21
Alright ill check them and let you know
JDEMER21
Ok I found out that my water pump seized up and the belt broke off since its ran off a separate belt than my serpentine belt is it hard to replace and is there any issues that could have cause when it seized up
SEANGRANT00
  • EXPERT
  • 334 POSTS
Yes there could be internal engine issues. Did the engine quit running by itself or did you turn it off?
SPOILGURL1
Engine light comes on and sensor says engine coolant over temperature. The sensor was changed thinking that it was a defect but that wasn't it. There's no signs of car running hot the temperature gauge needle stays in the middle and doesn't move towards hot. So what is it cause mechanics been trying to figure out for over a week now
Jun 11, 2019 at 6:16 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
It sounds like it could be a blown head gasket causing the engine to run hot. Here is a guide that will help you confirm the problem
Also here is a guide to check out additional reasons for the engine over heating.
and
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
Please let us know what you find.
Cheers,
SPOILGURL1
Okay, I did the test and the head gasket is blown, I will have it repaired becasue I don't want to do the job myself. Great work you guys do here on this site. I love it :)
I wonder why the other mechanics couldn't find the problem?
WRENCHTECH
  • 20,760 POSTS
We try to cover all bases at 2CarPros, Glad we could help.
SPOILGURL1
Ill will tell my friends and family about this site, it actually helps people.
TAHESIAFORD
Good morning. Mine is doing the same thing as you mentioned above and so I checked the head gasket and it is the problem with mine too. Nice work 2Carpros
JACOBJADYN
I'm getting it too. The codes are P0301, P0303, and P0304. The computer said to change the EVAP control valve. I did. Still getting the same warnings.
  • 55,694 POSTS
Please post your question here:
Cheers, Ken
