Engine coolant light coming on
194,000 MILES • 4.0L • V8 • TURBO • RWD • AUTOMATIC
TED BUNDY
I just want to know if I can add a little water with antifreeze? The car is not overheating. Is it bad to add water?
Aug 4, 2016 at 11:38 PM
HMAC300
  • 48,601 POSTS
It depends where you live. the best is a 50/50 mix with water, but if you are adding a half gallon or less you are okay.
Aug 4, 2016 at 11:57 PM
