Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Jaguar
XJ8
Warning Lights
Low Coolant Light
Engine coolant light coming on
2000 JAGUAR XJ8
194,000 MILES • 4.0L • V8 • TURBO • RWD • AUTOMATIC
TED BUNDY
MEMBER
1 POST
I just want to know if I can add a little water with antifreeze? The car is not overheating. Is it bad to add water?
Aug 4, 2016 at 11:38 PM
HMAC300
Experienced Mechanic
It depends where you live. the best is a 50/50 mix with water, but if you are adding a half gallon or less you are okay.
Aug 4, 2016 at 11:57 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
