engine coolant leak?
120,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
VIJAY SONI
  • 11 POSTS
My car showed an engine temperature warning. I checked the coolant tank, and it was empty, so I bought one gallon engine coolant from 7-eleven and poured it in the coolant reservoir, but it almost immediately got empty again. I looked under the car and saw it was leaking like a slow tap from near the front of the car more from right front (passenger side) whereas the coolant tank is towards left side (driver side) of the car. Can I know where it is leaking from? radiator possibly?
Oct 16, 2022 at 4:41 AM
  • 110,248 POSTS
It could be the radiator, but there are a few things in that area that can leak. For example, radiator hoses, heater hoses, the water pump, and so on.
Here is what I suggest: First, take a look through this link and see if it helps you locate the leak:
https://www.2carpros.com/articles/car-is-leaking-coolant
If that doesn't help, you will need to pressure test the system. This will require a pressure tester, but most part stores will lend one to you. Here is a link that explains how it's done:
https://www.2carpros.com/articles/radiator-pressure-test
If you are uncomfortable doing either of these, wait until the engine is cold and take a few pics of where you are seeing the leak. If you can do it from under the vehicle, it may help.
Oct 16, 2022 at 2:15 PM
