My engine coolant fan won't work when I'm activating the A/C. It also doesn't work when the Engine is hot.
I jumped 12v to the fan and it starts to turn, so it seemed to be fine. I put in a new fan relay.
I guess the coolant fan switch is bad, and I need to know it's location. Just found one coolant temperature sensor in the thermostat housing, but it seems to be the one for the ECU, not for the fan, or does the fan become it's turn on command by the ECU?
Any ideas are welcome.
Jun 7, 2023 at 9:43 AM
