Engine Control Pin Out with wire color needed?
100,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
#0UL!G!ZZ
Hello guys,
First of all, I appreciate what you are doing, sharing valuable information and knowledge with us car enthusiasts.
I am trying to install the Bee-R rev limiter to my car listed above. However, I am not able to identify the Ignition cut wire and the NE+ crank wire. Does somebody perhaps have the 5S-FE ECM Pin Out or Know the color of these two wire and their Pin position? I will highly appreciate your help.
Thanks much!
Nov 29, 2022 at 11:22 AM
  • 110,248 POSTS
Because of the model year, my schematics are a little limited. So, I attached the powertrain management wiring schematics below which show the modules.
Now, this is for a vehicle without a factory immobilizer. If that is incorrect, let me know.
Let me know if this helps.
Note: I cut each pic in half to make them readable. I overlap them so you can follow from one to the next.
Nov 30, 2022 at 12:56 PM
#0UL!G!ZZ
Hi Joe,
Yes indeed, mine has no factory immobilizer. The wiring schematics will for sure be more than helpful. I already have the pin out of the 5S-FE engine control, now I'll be able to double check with the colors because the pin position seems to slightly vary off of my car's connectors.
I appreciate the hard time you gave yourself to provide me with this precious information bro.
Thanks a lot for your response.
Nov 30, 2022 at 6:47 PM
#0UL!G!ZZ
Hello Joe,
Is it possible for you to send me the whole map? That way I'll be able to download it.
Thanks!
Nov 30, 2022 at 7:42 PM
  • 110,248 POSTS
First, you are very welcome. When you say the whole map, I'm not sure exactly what is needed. The schematics above are for the entire power distribution circuit.
If you have a specific area, I would be happy to check to see what is available.
Dec 1, 2022 at 5:39 AM
#0UL!G!ZZ
First off I gotta tell you the Pin Out sent earlier were accurate for the Solara 2001 4cyl. Thanks again for that. I specifically need schematics of the cruise control system. However, I would like to have the schematics that involve the E7 and E8 plug off of the ECM as well.
Thanks in advance!
Dec 1, 2022 at 5:23 PM
  • 110,248 POSTS
If you look at pics 1 and 2, that is the schematic for the cruise control circuits.
Guess what I found. The ECM pin outs. The remaining pics are all connectors including c7 and c8.
Dec 2, 2022 at 12:52 PM
