Eengine computer
120,000 MILES • 3.0L • 6 CYL • AUTOMATIC
CONFIRMED
The car runs great, but I have been told that I have to replace the on board computer because its unable to be read by the emissions test computer. I was told that if there are problems with the computer then the car would show some symptoms, like hard to start or rough idling or other problems, yet my car runs perfect.
Mar 2, 2016 at 11:24 AM
HMAC300
  • 48,601 POSTS
it may be just a connection problem at the aldl where scanners hook up have it checked for a blown fuse or shorted wire.
Mar 2, 2016 at 10:08 PM
CONFIRMED
The wires and fuses were checked and they are all good. Thanks for the tip. I just don't want to buy a new computer, and I can't find a used one any where in my area.
Mar 3, 2016 at 12:52 PM
CONFIRMED
Also when you turn key the check engine light does not come on and the bulb for the light is good
Mar 3, 2016 at 12:56 PM
HMAC300
  • 48,601 POSTS
With a bad ecm the light may not come on as that is mostly for sensors etc. a professional will have to install the new ecm due to security. It has to be programmed in as it 'won't start. there are rebuilt ones available so any garage with a professional scanner can install this.
Mar 3, 2016 at 10:56 PM
