Engine compatibility years
193,000 MILES • 5.4L • V8 • 4WD
REGALDAVE
  • 15 POSTS
Having trouble nailing down what years I can pull a motor from for my F150. It's a 1999 with 8th digit L Vin 5.4 2 valve.
Mar 10, 2021 at 6:00 AM
STEVE W.
  • 15,404 POSTS
There are two versions of that engine depending on which heads it has on it. The non power improved and the power improved version. The difference makes it so that they don't interchange very well with the stock ECM.
If it's the base model engine the late 98-99 5.4 are the only ones that will fit. If it's the later 1999 with the better heads then you have from late 1999 through 2001 in the 2 valves.
The easiest way to tell is to look at the head casting numbers, the PI heads have that in the casting number. Like XL3E-2CDD-PI as the right hand head. While the non-PI are F75E-C20A
8 digit.
I suspect it's the non-PI engine which limits the years for swap to that design. If you go to
car-part.com and enter your vin number it might give you some extra options.
Mar 10, 2021 at 9:26 AM
REGALDAVE
  • 15 POSTS
Thank you for the info. that gives me all the info I need to make a wise decision on what direction I need to go in.
Mar 10, 2021 at 10:31 AM
STEVE W.
  • 15,404 POSTS
Ford didn't make it real easy when they started changing the engine around in those years. You could have the good 2 valve, the HO 2 valve or the three valve engines, which I would avoid like the plague they are.
If you need any other info please don't hesitate to return. Thank you for using 2CarPros
Mar 10, 2021 at 10:53 AM
REGALDAVE
  • 15 POSTS
The three valve would be an obvious difference under the valve cover, but what should I look for other then the PI in the casting number when figuring out what motor to look for?
Mar 10, 2021 at 12:40 PM
STEVE W.
  • 15,404 POSTS
The 2 valves are easy to tell apart from the Tritons. Year wise and if it has the PI casting suffix on the heads are the telltale differences in the 2 valves. What is the issue with your current engine? If it's just wear you might consider rebuilding it unless you can get an engine for a lot less.
Mar 10, 2021 at 1:14 PM
REGALDAVE
  • 15 POSTS
When I bought the truck for my daughter the freeze plugs needed replaced. I did that and filled it with coolant it spayed it everywhere pretty sure a cylinder filled with coolant. And I did forget to mention the truck has a Triton v8 badge.
Mar 10, 2021 at 2:34 PM
STEVE W.
  • 15,404 POSTS
Sounds like it may have had water in it and froze. Not a good thing. Look it over and see what it has for castings, they may have stuck a PI in it and that would make it a bit easier to find a replacement. Then you just need to determine if you want a used engine or a re-man. If the truck is in good shape you might opt for that, but a couple things to check over first. Look over the frame real close, they went to the fully boxed frames and they have a bad habit of rusting out from the inside. A few taps with a hammer would show that. Then be sure the body and box mounting channels are good for the same reason. If they are good and the body solid, a re-man might be a good option, most have a 3 year warranty vs a used 30-90 day, but they will be more money.
Mar 10, 2021 at 3:42 PM
REGALDAVE
  • 15 POSTS
Thank you for the info. I think I have my Sunday all planed out for now, lol.
Mar 10, 2021 at 4:31 PM
  • 110,248 POSTS
I noticed it's been a couple of days since we heard from you. I was just curious if any progress has been made or if you have any new questions.
Take care and God Bless,
Mar 13, 2021 at 12:03 PM
REGALDAVE
  • 15 POSTS
I haven't had time to find the casting numbers on the heads. hopefully I get to that today.
Mar 14, 2021 at 12:48 AM
  • 110,248 POSTS
Not a problem. Let us know if we can help or if you have other questions.
Mar 14, 2021 at 11:51 AM
REGALDAVE
  • 15 POSTS
My 1999 5.4 F150 does have the PI heads and I've decided to go with a remanufactured engine. what all casting numbers do I need when ordering the replacement engine?
Apr 4, 2021 at 4:57 PM
STEVE W.
  • 15,404 POSTS
Just be sure to tell them you have the Power Improved heads and it's a 1999. Block F75E-AG
Heads XL3E-C20D-PI
Apr 4, 2021 at 10:35 PM
REGALDAVE
  • 15 POSTS
I didn't know if I needed the crank casting number and I don't quite have the old motor out yet to get all the numbers.
Apr 5, 2021 at 12:23 AM
STEVE W.
  • 15,404 POSTS
You shouldn't as long as it's for the correct year.
Apr 5, 2021 at 5:24 AM
REGALDAVE
  • 15 POSTS
Thank you for the info. I'm ordering the engine from the local parts store hopefully won't have to wait too long.
Apr 5, 2021 at 5:27 AM
STEVE W.
  • 15,404 POSTS
Usually it depends on what the builders have on hand. I can normally get an engine in about 2 days, unless it's some odd one where there are none on hand. Then they will sometimes have me ship the core in, they go through it and ship it back. That can be a mess if the core engine has problems in the hard parts like a cracked block or bad head.
Apr 5, 2021 at 12:40 PM
REGALDAVE
  • 15 POSTS
Okay, so new problem on my 19999 f150. on the fuel rail there is a valve to release pressure and it is leaking. can I tighten it like a bicycle tire valve or replace the internal valve?
Apr 26, 2021 at 4:37 AM
STEVE W.
  • 15,404 POSTS
That isn't really to release the pressure it's a test port. If it is leaking they can be tightened or replaced. You need the correct one though as they are high pressure and fuel resistant using viton seals.
Apr 26, 2021 at 5:35 AM
REGALDAVE
  • 15 POSTS
Okay, thank you. I will try tightening it if that doesn't work I will order a new one.
Apr 26, 2021 at 6:54 AM
STEVE W.
  • 15,404 POSTS
Most of the better parts stores will usually have them on the shelf. Just be sure it's one for fuel and not AC or tires.
Apr 26, 2021 at 7:24 AM
REGALDAVE
  • 15 POSTS
So I put in a remanufactured engine in my truck after a broken rod took out the old engine, I'm now getting a lot of blue smoke from this new engine after it has warmed up under load and idle. what should my next step be?
May 1, 2021 at 9:27 AM
STEVE W.
  • 15,404 POSTS
I would contact the company that you got it from first, doing anything else could void any warranty on it. It might just need to be run hard a bit to get the rings to seal but they should be able to advise you. Then do what they say first. If that doesn't work tell them and return here.
May 1, 2021 at 11:30 AM
