Engine compatibility
140,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
TRIPPLEF
Is an 8th digit 7 compatible to an 8th digit A?
Oct 18, 2020 at 4:34 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
If you want to give me the VIN- vehicle identification numbers and both model years of the Escapes I can look up to see if they are interchangeable. Hope this helps and thanks for using 2CarPros.
Oct 18, 2020 at 5:07 PM
TRIPPLEF
It is a Fusion 2010 A for the 8th digit in vin going into a 2010 Escape 7 for the 8th digit both 2.5l.
Oct 18, 2020 at 8:03 PM
Good morning,
The long blocks are the same but there are differences with the intake and exhaust manifolds.
You will need to strip down the donor motor to a long block and change over the external components from your engine to the donor motor before installing it in the car.
The motor must be exact when you install it to be sure everything will hook up properly and perform as intended.
Oct 21, 2020 at 10:08 PM
DANNY L
  • 5,648 POSTS
Hello again.
If you need any type of repair guides or reference material for this engine swap we are here to help. Thanks again for using 2CarPros and keep us updated.
Danny-
Oct 26, 2020 at 4:29 AM
