Can I pressure wash my engine without hurting anything?
48,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
JESTEP1966#
I was in heavy mud and under my hood is filthy. Is there anything that I can't get wet?
Feb 5, 2021 at 7:17 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, there are a few things to stay away from to be safe. Mostly the computer control. I would mask off the alternator, PCM, under hood junction block, and any other computer. This would be a good safeguard to prevent any glitches from happening. Hope this helps and thanks for using 2CarPros.
Feb 5, 2021 at 12:18 PM
STEVE W.
  • 15,409 POSTS
I would avoid using a pressure washer on that vehicle under the hood. FCA connectors are real bad for having sealing issues and there are a lot of them. If possible you would want to use more of a house pressure line and still stay away from much of the electronics.
Feb 5, 2021 at 2:03 PM
