Engine coil/spark plug
301,755 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
ADAMWAHLEN69
My engine coil number two is crackling and sparking outside of the plug and the metal ring inside the plug is cracked and it is causing my cylinder to misfire a lot.
May 28, 2019 at 1:39 PM
SCGRANTURISMO
  • 4,897 POSTS
I would recommend replacing the ignition coil and the spark plug as well. If you choose to do so, I would recommend replacing all of them at the same time, but it is not necessary, but highly recommended. I would also replace the spark plug wires at the same time. In the diagrams down below I have included the directions on how to test your ignition coil to determine for sure if it is bad or not. It will require you to use a multi-meter, so I have included a link below for you if you are not familiar with how to use one.
And here is a guide on replacing your spark plugs as well:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
May 28, 2019 at 5:15 PM
