Engine Codes P145C & P0497
105,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RONCALI
  • 5 POSTS
These codes have been coming up intermittently for a year and stay on for about 100 miles then go off. The check engine light is coming on more often now. Time to repair.
Aug 30, 2016 at 12:40 PM
HMAC300
  • 48,601 POSTS
145 is 3rd O2 sensor slow response which is behind converter, and 497 is low purge flow for evap system which can be several things but must be smoke tested for a leak first.
Aug 30, 2016 at 11:50 PM
