what cause engine codes P1148 and P0031? theses codes appear after i replaced the ignition coils and spark plugs
Nov 20, 2026 at 4:28 PM
MECHTRIX
✓Experienced Mechanic
These codes indicate a problem with the upstream 02 sensor at bank 1 sensor one ..02 sensor heater circuits having trouble operating normally circuit low voltage it also cuald be having trouble reading the incoming exhuast gasses due ti a woring issue or jist being old amd worn out its usually a pretty easy replacement ...most likely it needs a new sensor .good luck hope this helps
Nov 20, 2026 at 5:17 PM
JOE1953
MEMBER
I notice a female connector is disconnected near the firewall behind the upper intake manifold i'm not sure is this causing the codes and where the connector wires go to.
