They mean the fuel system is too lean and the computer has reached it's adaptive limits and can no longer compensate for it.
On a Ford, 90% or the time this is caused by a bad vacuum leak at one of the large rubber hoses or connectors.
You can perform a smoke test to locate it if it's not obvious.
Jan 22, 2016 at 12:33 AM
PAPA1HUNDRED
MEMBER
Wow thanks for responding so quickly,amazing, is a smoke test something I can do myself or do I have to take into a shop. THANKS. AGAIN
Jan 22, 2016 at 12:52 AM
WRENCHTECH
✓Experienced Mechanic
The smoke machine costs about $1000 so I doubt you have one. You probably need to have someone do it for you.
