engine code P0455
140,000 MILES • 3.5L • V6 • AUTOMATIC
LANCEH11
Engine code P0455 has appeared in my car. I have cleared the code after tightening the gas cap. About a two days later, the code came back. Repeated the same process, and the code has came back two days after that. Could this be a problem connected to the vapor canister solenoid?
Oct 10, 2016 at 12:55 AM
HMAC300
  • 48,601 POSTS
that codes is a large leak detected in evaporator system which gas cap is part of. It should really be smoke tested to see where leak is, but it could be a bad solenoid or dirt in it not allowing it to close.
Oct 10, 2016 at 2:36 AM
PHILJACK
I have a 2007 Chevy Impala, and I just had the Code P0455 come up. What is the problem? It has about 120,000 miles on it and it has a 3.5 Litre V6. I just put a new gas cap on about a week ago, and the code P0455 still shows up, any ideas?
Feb 7, 2019 at 11:37 AM
SCGRANTURISMO
  • 4,897 POSTS
DTC 0455 is that a leak has been detected in your vehicles Evaporative Emissions System(EVAP). Your EVAP system consists of a charcoal canister, vapor line going from your fuel tank to the canister, and lines to a solenoid or a EVAP Purge Flow sensor, and more hoses/lines going into the throttle body. Basically this is emission control system where fuel vapors are routed and stored in a charcoal canister until the vehicles Power-train Control Module(PCM)/Electronic Control Unit(ECU) a.k.a. computer decides it is a good time to introduce it into the throttle body to go into the combustion chambers and disposed of in the normal combustion cycle of the engine. Here is a link to a guide that should help you run down the problem:
https://www.2carpros.com/articles/evap-system-code-repair
Go through it and let us know what you find out. If you need further assistance, we can go from there.
Thanks,
Alex
2CarPros
Feb 7, 2019 at 1:26 PM
