Check engine light on with code P0421, how do I fix it?
130,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JACOBPAULSEN
  • 64 POSTS
Check engine light on, how do i fix this?
Any ideas of the cause?
Aug 24, 2022 at 8:31 AM
  • 110,248 POSTS
The code is related to the warm-up catalyst operating below the threshold. The most common causes for this code are a faulty or worn catalytic converter, a faulty heated o2 rear sensor, an exhaust leak before the upstream sensor, or the PCM itself.
Here is how it works. The signal from the rear heated oxygen sensor should differ from the front heated oxygen sensor. That is because the catalytic converter purifies exhaust gas. When the catalytic converter has deteriorated, the signal from the front heated oxygen sensor becomes similar to the rear heated oxygen sensor. Once the PCM recognizes this, the code is set.
So, by any chance do you have a live data scan tool that we can compare the front and rear oxygen sensors? Also, are there any bad odors coming from the exhaust?
Let me know. Also, let me know if there are any exhaust leaks.
Aug 24, 2022 at 1:21 PM
JACOBPAULSEN
  • 64 POSTS
This has been this way for about 10 years I'm just finally choosing to do something about it.
There's no exhaust leak or foul odors.
Aug 25, 2022 at 3:50 AM
JACOBPAULSEN
  • 64 POSTS
I might have one i'll let you know when I get home.
Aug 25, 2022 at 3:51 AM
  • 110,248 POSTS
Sounds like a plan. Also, if you have a live data scan tool, watch how the sensors react. The front and rear shouldn't be nearly the same. If they are, the converter isn't doing its job.
If you don't have a live data scan tool, here is a link that explains how to test an oxygen sensor using a voltmeter or multimeter.
https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
Aug 25, 2022 at 11:09 AM
JACOBPAULSEN
  • 64 POSTS
So, today I turn on the car I still haven't had time yet, but today I was stopped at a stoplight pressed on the gas pedal and the car starts jerking forward very fast.
I turned on the hazards and turned into a parking lot, put the car in park, and let it rest for a few seconds.
Then I put the car back in drive and it stopped jerking when i pressed on the gas.
Four months ago, the car would start then immediately turn off.
Could these be related?
What could be the issue be?
Aug 31, 2022 at 4:13 AM
  • 110,248 POSTS
They could be related. However, I have a feeling we have a fuel issue related to the issue. Have any new codes turned up?
Aug 31, 2022 at 11:08 AM
JACOBPAULSEN
  • 64 POSTS
Nope just the P0421.
Aug 31, 2022 at 11:46 AM
JACOBPAULSEN
  • 64 POSTS
forgot this.
Aug 31, 2022 at 11:50 AM
  • 110,248 POSTS
By chance, do you have the voltages for O2S1? I don't like how the voltage is somewhat flatlined in pic 3 above. As far as the fuel trims are concerned, they appear on target.
Let me know if you have that info. Also, the flatline may simply be from driving on a flat surface and not changing the throttle pressure.
Aug 31, 2022 at 12:16 PM
JACOBPAULSEN
  • 64 POSTS
took it around the block.
Aug 31, 2022 at 1:53 PM
  • 110,248 POSTS
I have a feeling it is sensor 1 that is bad. It shouldn't drop to 0v. It should stay between .1 and .9. Double check the connection. I say that because it seems to respond properly other than the drop to 0v.
Sep 1, 2022 at 11:25 AM
JACOBPAULSEN
  • 64 POSTS
where is the sensor located?
Sep 6, 2022 at 2:02 AM
  • 110,248 POSTS
Sensor 1 is located in the exhaust manifold. I attached a pic below showing its location.
If you plan to replace it, here is a link you may find helpful:
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Let me know if that helps.
Sep 6, 2022 at 10:48 AM
JACOBPAULSEN
  • 64 POSTS
The sensor was replaced the code is still there, next?
Sep 19, 2022 at 2:21 AM
  • 110,248 POSTS
Have you tried clearing the code to see if it returns? It may eventually turn off after the system completes different drive cycles, but to speed things up, I would clear it and see if it returns.
If you have done this, then we need to start checking the wiring. Also, if you want, here is a link that explains how to test a sensor. If you have luck with parts as I've been having, you may have gotten a bad one. LOL
Sep 19, 2022 at 12:15 PM
