Codes p0302 and p0202, loss off power while running and driving idle not strong?
50,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
LANCE CHAMBERS
  • 5 POSTS
Blinking check engine light, engine code p0302 and p0202 where should I start with repair spark plug/ fuel injectors?
Jun 5, 2023 at 10:52 AM
  • 110,248 POSTS
Based on the codes, I would start with the fuel injector. There is an issue with the circuit or injector and either could cause a misfire.
I attached a pic below. At the injector, there will be a brown wire with a white tracer. That wire should have battery voltage when the key is on. I need you to check that first. (See pic below)
If there is power, next, with the connector disconnected, do the following.
Take a test lamp and attach the alligator clip to the battery positive. With the light, probe the brown wire with a dark blue tracer. Have a helper crank the engine. While it's cranking, the test lamp should strobe on and off.
Do this and let me know the results.
See pic below.
Jun 5, 2023 at 2:29 PM
LANCE CHAMBERS
  • 5 POSTS
I appreciate the response!
After further inspection I’m not seeing the white wire only blue and brown, I attached a picture below to make sure we’re on the same page as to which wires, I should be testing!
Thanks again!
Jun 6, 2023 at 4:29 AM
  • 110,248 POSTS
There are two wires present at that injector. Both wires are brown in color, but one will have a white line/tracer through it and the other will have a dark blue one.
In your pic, you have an arrow pointing to the coil and I believe the injector. I circled what I believe is the injector. Also, I was able to find a better picture of the wiring for you.
Let me know if that helps.
Jun 6, 2023 at 2:02 PM
LANCE CHAMBERS
  • 5 POSTS
I finally did the test, everything happened just as you described, now the car is push to start, so when they cranked the car started. The strobe light flickered on and off just as you described when testing brown/dark blue.
Thank again for the response!
Jun 8, 2023 at 3:40 AM
  • 110,248 POSTS
Lance, is the misfire still present? If it is and we know the PCM and power supply are working as they should, suspect the fuel injector itself is faulty.
Jun 8, 2023 at 1:07 PM
LANCE CHAMBERS
  • 5 POSTS
Just as expected, I replaced the fuel injector and now I’m back on the road. I really do appreciate the help! Definitely a life saver joe.
Jun 10, 2023 at 5:39 AM
LANCE CHAMBERS
  • 5 POSTS
Let me know if it’s a way possible for me to send you something for helping me out. I really appreciate it!
Jun 10, 2023 at 5:44 AM
  • 110,248 POSTS
First, you are very welcome; I'm glad to know you got it going again. As far as sending me something, absolutely not, but thank you nonetheless. Your letting me know we got it fixed is all I wanted. LOL
You take care of yourself and please feel free to come back anytime in the future. You are always welcome.
Jun 10, 2023 at 1:05 PM
