I was driving along like normal with no check engine light whatsoever. (No check engine light through this entire experience) when I suddenly noticed the engine started to work harder to accelerate. Over the next couple drives (all within 24 hours) this continued with steps of not being able to accelerate uphill, not being able to exceed 35 mph uphill, 30 mph on any surface, to zero drive power. Nothing obviously physically wrong. Sounds like a CatCon. I pulled codes with fingers crossed and got 5.
Again, with no check engine light. They are
P0076-intake valve solenoid
P0079-exhaust valve solenoid
P0031-upstream A/F O2 sensor
P0445-EVAP system leak/low pressure
P0037-downstream HO2S
Thanks for the insight and ideas. My current plan is to pull the Cat and verify pos or neg function.
Nov 16, 2023 at 5:34 AM
