I went to check what codes it had, and the engine light just flashed without any pause. What could that mean?
Dec 18, 2022 at 11:39 AM
✓Experienced Mechanic
That means there are no codes, are you having an issues with the car?
Dec 19, 2022 at 2:50 AM
BRETT HALEY
MEMBER
Yeah, the temperature gauge doesn't work all that well, constantly reads as just above cold. I'm worried that means the radiator fans won't switch on.
Dec 19, 2022 at 8:37 AM
Yep, I would replace the engine coolant sensor which should fix the gauge and allow the cooling fans to come on. Here is the location of the sensor below. Please let us know what happens.
Image (Click to enlarge)
Dec 20, 2022 at 2:58 AM
BRETT HALEY
MEMBER
Okay, so, I replaced the coolant temperature sensor, and it made it a little better, but the temperature gauge is still sitting low (just above cold) and I'm wondering if I need to replace the thermostat, your input would be much appreciated.
Dec 21, 2022 at 7:14 AM
Yep, it sounds like it may be stuck open. here is a generic guide to help you through the steps and the thermostat location and how to replace it in the images below:
