engine code 0443
116,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JUNEBUG77
code 0443 stays on.
Nov 19, 2017 at 1:11 AM
  • 110,248 POSTS
The code is an EVAP code indicating there is a short to the vent valve. Check the wiring to see if there are any damaged or melted wires. I will also say that this code can show up if the vent is stuck in the closed position.
Nov 21, 2017 at 11:21 AM
