engine code p0351
186,000 MILES • V8 • FWD • AUTOMATIC
JOE1953
  • 806 POSTS
the engine service light is on and i scan the computer it show a code PO351 and sometime the engine have miss what is the cause and what is the meaning of the PO351 code?
Mar 24, 2016 at 1:55 PM
HMAC300
  • 48,601 POSTS
it's a coil pack problem see pic could be any of the things listed.
Mar 25, 2016 at 12:12 AM
JOE1953
  • 806 POSTS
how do i test the:
.Ignition Coil Packs
.Ignition Coil Wiring Harness
IGN STAR/RUN CIRCUIT TO COIL PACK
Mar 25, 2016 at 2:01 AM
JOE1953
  • 806 POSTS
How do I test the: . Ignition Coil Packs
. Ignition Coil Wiring Harness
Mar 25, 2016 at 3:12 AM
  • 55,561 POSTS
It will only fail when in operation and is difficult to test, the coil packs had problems on this car.
Mar 25, 2016 at 4:37 PM
JOE1953
  • 806 POSTS
how do I know which coil to replace is there a test I can do?
Mar 25, 2016 at 5:46 PM
  • 55,561 POSTS
Yep you can follow this guide it should help you.
Mar 25, 2016 at 7:02 PM
