Engine Cleaning Beginner ( Product Recommendation ) effective / safe
111,000 MILES • 3.1L • V6 • 2WD • AUTOMATIC
MERX2006
I need to clean engine of oil build up to make possible to see oil leak. It isn't Coolant.
My Choices; Extreme Simple Green?
Meguiars Engine Cleaner?
Detailor's Pro Engine Degreaser?
last question; mechanic replaced Oil Pump drive O-RING to stop leak. Mechanic's reply about current oil drip - allow car a week before oil drips stop & that alot of oil buildup around transmission. If drip not stopped in a week return for inspection & recommendations - What do you think about my situation?
Sep 13, 2014 at 3:45 AM
HMAC300
  • 48,601 POSTS
I always used gunk myself then took to a quarter car wash and used that to clean it never had a problem with it. or a power washer if you have one
Sep 13, 2014 at 3:59 AM
MERX2006
I'm don't feel safe using a corrosive fluid around even covered old wiring in my '94 Buick Century 3.1
How about oil drip after replacing Oil pump drive O-Ring. How much time before drip stops?
Sep 13, 2014 at 4:06 AM
HMAC300
  • 48,601 POSTS
gunk is only fuel oil and not a corrosive its not going to kill you lol. if the thing is still dripping it's not fixed.
Sep 13, 2014 at 4:08 AM
