Engine check and slip indicator light stay on
179,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JACKY YAN
My car is listed above petrol. Yesterday when I was driving on high way the slip indicator and engine check yellow light were on. I tried to turned off and restart engine after I arrived my destination later. But the lights are still on. When I turn on the key, the engine check light stay on after dashboard finish self check. Then when I move the car the slip indicator shows again and stay on all the time.
I have disconnected the negative of battery for more than five minutes and check the gas cap but it doesn't work.
I tried to use jump wire to get fault code. The ABS light flashing shows 41 which means abnormal voltage.
What should I do next step?
Plus, all other performance of my car is good.
Thanks,
Jack
Jul 19, 2019 at 7:43 AM
  • 110,248 POSTS
Welcome to 2CarPros.
First, I need you to scan the computer using an OBD2 scanner. Here is a video showing how it is done:
https://youtu.be/YV3TRZwer8k
I need to know what codes you get. I'm not familiar with a 41 and couldn't find it on the manufacturer's list.
Next, the slip light is usually related to a faulty wheel speed sensor, but we will wait to see what the codes say. In the meantime, if you want to check wheel speed sensors, here is a link that explains how:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let me know what you find and what codes are pulled.
joe
Jul 20, 2019 at 3:10 PM
