Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercedes Benz
C200
Engine
engine check error and had to change the plugs?
2016 MERCEDES BENZ C200
85,000 MILES • 2.0L • TURBO • 2WD • AUTOMATIC
FYABUPI
MEMBER
1 POST
I had the engine check error and had to change the plugs, but after clearing the error, it still comes up.
Dec 11, 2024 at 2:53 AM
Experienced Mechanic
What error codes is it? You could have a bad ignition coil or low compression. here is a guide to help you go over the causes of an engine misfire:
Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Image (Click to enlarge)
Dec 11, 2024 at 5:33 AM
Add image or video
Ask a new question
Check engine light
Engine won't start
