Engine replacement/swap
2007 NISSAN XTERRA
40,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
RICKOBABA
Engine of my vehicle listed above got bad and needs replacement. Can I replace the 4.0L engine with a lesser say 3.3 L? What are the pros and cons of the downgrade?
Nov 2, 2019 at 3:49 AM
Good afternoon.
The only pro would be better mileage.
The cons will win. You will need the engine, transmission, complete wiring harness, exhaust system and different sensors and ECM.
A very huge and expensive project to change it.
Would you consider a used 4. engine?
Nov 2, 2019 at 4:48 AM
